Author Topic: Help...What does this do??  (Read 1184 times)
Offline MrDan
« on: 26 December 2006, 14:33 »
Had the cutting out problem on my Mk3 N Plate 8V, Found a hole in the corner on this tube,
So i started to remove it and found this thing was snapped
Luckilly got the seal out without anything dropping into the engine head
hose on the engine side of the assembly looked like ths
Is that right? (full of yellow crap)
I have a basic understanding of engines but really cant afford to go to a dealer at the moment, would love to fix it myself
Obviously i need to replace both parts, but what does it doo? and can i run the car without it ?
Offline Dave-iow
Re: Help...What does this do??
« Reply #1 on: 26 December 2006, 14:35 »
Iyts a breather as far as I know mate. Thats probably why its wasnt running right on idle
Offline MrDan
« Reply #2 on: 26 December 2006, 15:06 »
cheers la. so its a replace and hope for the best?
« Reply #3 on: 27 December 2006, 09:47 »
yep, the white buildup is completly normal, its just condensation from the engine block.  Its worse this time of year, especially if you only do short journeys.  Try to get the pipes from a scrappy if you can, VW are pricy!
Offline MrDan
« Reply #4 on: 27 December 2006, 10:40 »
Thanks peeps, just on the lookout now for the parts, ill have a ride around the scrappys tomorrow i think,
£31 + Vat for the small rubber bit from the stealers :-0
