Author Topic: No Heating!!  (Read 4137 times)
Offline Dipesh
Re: No Heating!!
« Reply #10 on: 27 December 2006, 13:03 »
look near the bulk head, its this metal thing thats got a small cylinder and a big one and water pipes attached to it.
Hope that helps!
Offline Chantuz
  • MissMk2Golf
Re: No Heating!!
« Reply #11 on: 27 December 2006, 13:15 »
I'm having that problem too, even if it is the heater matrix its not a hard job AT ALL, you dont have to take the dash out. So should be cheap enough, mines getting done next week, only £34 for the matrix from andrew page.  :nerd:
Offline 1 Lp
Re: No Heating!!
« Reply #12 on: 27 December 2006, 18:31 »
just purchased a new bypass vavle, gonna fit it and see if that helps
VWs are like women, they need love care and attention
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: No Heating!!
« Reply #13 on: 27 December 2006, 18:46 »
Flushed my matrix todaya nd replaced the valve and it pretty uch didnt do sweet FA gives me soem ehat but nothing to write home aobut, and at least the lukewarm stays now  :grin: balls..
after much deliberation and pushing by rubjonny, stories of nobody ever knowing of thei amtrix to die witht his, many mk2s not ahving it done etc, it seems fair enough jsut t chenge the hoses and elminate the valve, considering one end of the metal valve on mine is chipped out by a huge chunk to  :huh:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline 1 Lp
Re: No Heating!!
« Reply #14 on: 29 December 2006, 21:15 »
changed the bypass vavle, and still not heat. I think I need to change the expansion tank cap, because I haven't got any pressure in the tank.
so plan is tommorrow
1. purchase cap
2. bled of the system see if this helps
sacvwgolf
Re: No Heating!!
« Reply #15 on: 29 December 2006, 21:24 »
have the engine got to be runing to have hot air?
Offline 1 Lp
Re: No Heating!!
« Reply #16 on: 29 December 2006, 22:16 »
ehy??
Re: No Heating!!
« Reply #17 on: 29 December 2006, 22:33 »
you arent going to warm up the water, or have it moving witohut a running engine, aty least not on a 1.3 cause the waterpump is driven by the cambelt.
thats why you have the initial bit of cold air till it all warms up then you get warm bowers of course..
1 Lp, make sure you get the blue cap from VW i chagned mine from a blackone after being advised, was the best thing I did, my old one was rusted solid so the little plate didnt even move..  :huh:
Quote
sacvwgolf
Re: No Heating!!
« Reply #18 on: 29 December 2006, 22:37 »
thanks i was worried for a min.
Re: No Heating!!
« Reply #19 on: 30 December 2006, 00:51 »
No problem mate. If you come to change the cambelt I recommend cahnging the pump at the same time as it's the tensioner for one.. Mine was so badly rusted in it took 6 guys trying many different ways to get it out, ending up on a lad getitng a big bar to smash it out.. even the O Ring had rusted over.. it's on my project page  :smiley:
Just a little tip if you come to it anyrate  :wink:
Quote
