Author Topic: No Heating!!  (Read 4135 times)
Offline 1 Lp
No Heating!!
« on: 26 December 2006, 11:27 »
I got no heating in my car. I've just changed the thermostat, but still have no heating in the car. all the pipes seem to warm up ok, no heating in the interior of the car.
what it be?? hopefully its not the heater matrix??
VWs are like women, they need love care and attention
Offline 8vRicey
  • Silver Mettalic 8v GTI
Re: No Heating!!
« Reply #1 on: 26 December 2006, 12:05 »
Search.
There must be a post every day on the subject !  :rolleyes:
Computer games don't affect kids, I mean if Pac Man affected us as kids, we'd all be running around in darkened rooms, munching pills and listening to repetitive music.
Offline T_J_G
Re: No Heating!!
« Reply #2 on: 26 December 2006, 14:29 »
use the search there is alot of information on this site about having no heat.
I don't have heaters, but just flushed coolant and replaced with new stuff and it seems a bit better (though may be imaginig it)
It could be:
lack of coolant
bypass valve buggered
heater matrix broke
(list thanks to RubJonny)
I'd suggest removing the bypass valve and replacing it or bypassing it (lots of information on here bout that too) and see where you are from there.
Tim
Offline Mr Blue
Re: No Heating!!
« Reply #3 on: 26 December 2006, 17:29 »
if your carpet is wet then your matrix has probably blown.
bypass valves are for girls. replace those with some central heating pipe :evil:
check for leaks in the cooling system. You can get air in the system with leaks
does take a while to bleed the system
Offline T_J_G
Re: No Heating!!
« Reply #4 on: 26 December 2006, 19:36 »
After taking mine out earlier,it's definitely more heat in the sytem. However not as hot as i'd like but the car doesn't have a stat so it won't get warm that quick. So that may explain that.
I suggest flushing the coolant system and fill with new coolant. May improve the situation and then go from there...
Tim
Offline 1 Lp
Re: No Heating!!
« Reply #5 on: 26 December 2006, 21:40 »
well without the blower on the car has a faint heat coming through the vents (I take it this is engine heat) but as some as you put the blowers on it blows out cold air.
very confusin
Offline T_J_G
Re: No Heating!!
« Reply #6 on: 26 December 2006, 22:34 »
very confusin
That seems a tad similar to mine now....before hand there was no heat at all. Could be you bypass valve, though i'm no expert just going out what people here have said...i'm going to do mine early January,along with new header tank + cap,but that's a whole
other story.
Tim
Offline Dipesh
Re: No Heating!!
« Reply #7 on: 26 December 2006, 22:53 »
I did the by pass mod on mine, best thing i ever did!
Offline 1 Lp
Re: No Heating!!
« Reply #8 on: 27 December 2006, 10:54 »
think I might Have to try that... cant take having no heat, its cold outside
Offline Notis_kr_16v
Re: No Heating!!
« Reply #9 on: 27 December 2006, 11:06 »
my 16v have the same problem.where is that bypass valve????
a photo please!
