Author Topic: G60 front brakes.  (Read 2384 times)
Offline Helios_Blue_Valver
G60 front brakes.
« on: 17 January 2004, 22:27 »
I have 256mm front brakes on my car now but am thinking about upgrading to 280 mm G60 front brakes. What all do i need for the swap other than the Calipers and Disks? Do i need the caliper carriers as well or do the 256mm's fit them. I know I need new front splash gaurds. Are the G60 Calipers 4 pot?
Offline Dizzie
  • Make friends with your fast
Re:G60 front brakes.
« Reply #1 on: 17 January 2004, 23:58 »
the G60 callipers I've got aren't 4 pot. Same as old ones, just bigger.
« Reply #2 on: 27 January 2004, 19:52 »
do they fit the standard 16v front caliper carriers though? Or is this another item to buy? Not too sure myself. Later m8
Offline Dizzie
« Reply #3 on: 27 January 2004, 22:25 »
when I was researching this I was told I'd need:
280mm discs
calipers
16v carriers
22.2mm master cylinder else I'd have my foot on the floot before I started to slow down.
Offline Gambit
« Reply #4 on: 28 January 2004, 09:23 »
you need G60 carriers
Offline cheech
« Reply #5 on: 28 January 2004, 10:04 »
You can use the 16V 256mm cariers, you just must modify the sliders as the discs for the G60 are different width from the 16v ones! G60 carriers would b best though!
