Author Topic: Indicators  (Read 1051 times)
Offline Stu-1.8T
  • Quit your Jibba Jabba
Indicators
« on: 17 December 2006, 13:16 »
The indicators have stopped working on my wife's Mk4 golf.
They will work every now and again, but either flash really quickly or not at all (all the bulbs are o.k)
I'm confident that it's not a problem with the indicator Stalk as it has the same problem when the hazzards are switched on.
Is this most likely to be a failed relay unit? and if so does anybody know where it's located?
Stu
If only everything in life was as honest as Car ads......... :undecided:
Offline Stu-1.8T
Re: Indicators
« Reply #1 on: 20 December 2006, 21:17 »
I have found the fault. The problem was with the Hazzard warning switch which is also the relay unit. I swapped it over with the one out of my Golf and this fixed the problem. So just need to order a new hazzard switch.....hopefully this should be fairly inexpensive :undecided:
Offline 152GTI
Re: Indicators
« Reply #2 on: 22 December 2006, 17:53 »
Yeah I too had a similar fault!! A right pain in the ass!!!  :cry:
Offline Mantamad
Re: Indicators
« Reply #3 on: 22 December 2006, 20:10 »
Always handy when you have another car of the same model to swap parts with.
Black 2002 GT TDi 130
