Author Topic: HELP !  (Read 1821 times)
Offline illyun
HELP !
« on: 15 December 2006, 14:54 »
I am planning on driving my R32 to the south of Spain and looked into what I have to do to get my headlights road legal over there.  I assumed that I would just have to fork out £4 to £5 as before for some stickers.  Then I found out that you cannot use these as the Mk5 headlight shapes do not have any stickers that work with them.  No problem I thought as I had heard that you can buy headlight protectors that do the same job - can't cost more than £20-35 I thought.  So I rang the dealer and was told that the headlight protectors can't be used either as the xenons generate too much heat.  Solution?  You have to flick a lever on the back of the headlight.  Cost? £147 to change to Euro-spec and another £147 when you come back to change to UK-Spec!!!  Its all in the labour cost as its 2 hours labour taking the grill and stuff off.  So VW are basically saying that it will cost almost £300 to allow me the privilege of driving in Europe.  I cannot believe that they did not consider this when installing the xenons on this model.  I will be ringing and writing to VW customer services as this cost is unacceptable and I think there is a safety issue here too because the work will be done in Ipswich and then I will be driving down to Dover and blinding drivers on the opposite side of the road as my xenons will be Euro-spec.  :angry: :angry: :angry: :angry: :angry:
I am considering doing this myself.  Is it easy to remove the grill - I feel a bit apprehensive as it is a brand new car and what worries me is that I do not want to damage the xenon units by doing something that I shouldn't
Mk1 GTI Campaign, Mk5 GTI Edition 30, Mk6 GTI (Coming Soon...)
Offline wantmygti
Re: HELP !
« Reply #1 on: 15 December 2006, 15:26 »
I've done it on an Audi. Not too hard just fiddly, and you have to remember where the levers were when you started!
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline The Doc
  • E63s Estate - Vito Sport
Re: HELP !
« Reply #2 on: 17 December 2006, 13:30 »
"xenons generate too much heat"
Thats BS mate - VW dealers talk some sh1t!
I will go look at my missus ones and try to do a "how to" if I can  :wink:
Offline The Doc
Re: HELP !
« Reply #3 on: 17 December 2006, 14:02 »
« Last Edit: 17 December 2006, 14:16 by The Doc »
Offline The Doc
Re: HELP !
« Reply #4 on: 17 December 2006, 14:18 »
 Euro-spec wont cause any problems over here BTW as beam is "flat" - you will see what I mean when you do it!
