Author Topic: Does anyone know where????  (Read 3884 times)
Veedubgt18v
« on: 17 January 2004, 02:52 »
The oil temp sensor for the mfa is? is it on the block or what?  ???
Offline mk1
Re:Does anyone know where????
« Reply #1 on: 17 January 2004, 09:21 »
I think it's in the oil filter housing, near the pressure switch. Single terminal with a "nail" type head, white -green wire I think.
Steve.
Offline Helios_Blue_Valver
« Reply #2 on: 17 January 2004, 11:56 »
16v is on the back of the block. not sure about 8 valve though.
Offline OP
« Reply #3 on: 17 January 2004, 13:31 »
On the top of the oil filter housing, small slide on female spade connector on the top. It slides on from the side as I found out the other week  ::)
OP
http://www.dubberware.com "Personalise Your Ride" Stickers, Clothing Etc.
Offline Dizzie
  • Make friends with your fast
« Reply #4 on: 17 January 2004, 19:15 »
aiiii. the front is the temp and the rear is the pressure. I have a oil pressue sender screwed into it ;D
« Last Edit: 17 January 2004, 19:15 by Dizzie »
Veedubgt18v
« Reply #5 on: 17 January 2004, 20:08 »
so if i got volts, oil temp and pressure gauges i put the audi twin post sender in the rear of the oil filter mount for the oem sensor to attach to and the oil pressure gauge to attach to as well? if you know what i mean!
whats the thing on the right side of the block just under the cylinder head? how do i connect up the oil temperature gauge?  ???
HELP!!
Veedubgt18v
« Reply #6 on: 17 January 2004, 20:14 »
or can i put the twin post sender in the side of the block and have oem oil pressure and the gauge running off that?
i could then attach the oil pressure gauge to the stock one on top of the oil filter mount?
would this mean i wouldnt have a temp reading on the mfa?
i have heard you can get t pieces to resolve this but where from??
Offline mk1
« Reply #7 on: 17 January 2004, 21:21 »
I think I know what your trying to do, remove the oil press sensor from the filter housing, fit the "twin post" sender in its place. Wire the oil pressure guage to the correct terminal and the oil light to the other. Oil temp wire, just link into the wire that "talks" to the MFA and both should work  ;).
Steve.
Offline Dizzie
« Reply #8 on: 17 January 2004, 21:44 »
the one on the side of the block is the 0.3 bar oil pressure point. the one on the back of the oil cooler is the 1.8 bar point. you only need it on the 1.8 bar point. the temp goes infront of it, but it's very close to the dizzy.
Veedubgt18v
« Reply #9 on: 18 January 2004, 09:32 »
ok i will leave the thing on the side of the block alone!
i wil put a twin pole sender onto the 1.8bar location on the filter housing and wire it for a)the original sender and b)for the new gauge
The temp one is there something there that i just connect to or do i need a whole new sender?
cheers for your help guys much appreciated!!  :-*
