Author Topic: Electric Window "clunk click"  (Read 1082 times)
Offline chris_Mk3Annivers
« on: 09 December 2006, 22:21 »
hi
my driver side electric window has decided to throw a wobbly..
when i press the button down or up i can hear the click inside the door when i press/depress the up/down button.. does this indicate power is there but no motor..?? or has something else happened..??
Regards
Chris
Offline GuvGTI
Re: Electric Window "clunk click"
« Reply #1 on: 12 December 2006, 01:02 »
can you hear a noise when u press the electric window switch, if you do then the motor is working and your regulator is damaged. possibly  a faulty wire. Anyway same prob happened to mine and bought a window regualtor from vw and got a garage to fit it instead of them. Touch wood works fine no problems.
Offline gtitdi
« Reply #2 on: 12 December 2006, 07:06 »
I had exactly the same problem when some of the wires in the door hinge inside the rubber boot had snapped, might be worth a check.
« Reply #3 on: 15 December 2006, 21:46 »
thanks guys i shall check on my day off and report backĀ   :wink:
if its any clearer this happened after a full vallet so im thinking some sort of cleaning foam/spray got down the side of the button
« Last Edit: 15 December 2006, 21:48 by chris_Mk3Annivers »
