Author Topic: Relay shaft bushes/balls!  (Read 103840 times)
Offline systemseiko
Re: Relay shaft bushes/balls!
« Reply #30 on: 25 January 2007, 03:15 »
Well worth the £7.00,  i ended up paying £35.00 + vat from my local Vw dealer as he wouldn't sell the polypro bush seperate,  again made some difference to my gear change but ripped off at £35.00,  you should also start selling the Vw alignment tool as a package as this is a god send when resetting your linkage.
If it is a 90 mph per hour wind and you drive your car at 90mph downwind, if you stick your head outside would you feel the wind?
« Reply #31 on: 25 January 2007, 09:25 »
I have a cad drawing of the tool tucked away safely if anyone needs it ;)
Offline mk2mark
« Reply #32 on: 25 January 2007, 10:37 »
Maybe I should. Is there any reason why 2 or 3mm plate would be too light? I can't see any reason but all the ones I've seen seem to be heavier. Rubjonny If you send that CAD drawing on I could look into it!
By the way crevice I got your payment and I'll post that out today.
« Reply #33 on: 25 January 2007, 10:57 »
2/3mm should be plenty strong enough, but it needs to be chunky enough so it wont wobble about when fitted to the gearstick I guess?
Offline mk2mark
« Reply #34 on: 25 January 2007, 11:12 »
Well I got your email so I'll have a chance to try out a few in different thickness and see what works.
Offline cняis
« Reply #35 on: 25 January 2007, 12:24 »
thank you!
Offline bomp
« Reply #36 on: 25 January 2007, 14:30 »
Yeah, I'll be interested in a gear alighnment tool and a relay shaft bush as a kit.
Post the price when youv'e finished investigating :)
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Breaker
« Reply #37 on: 26 January 2007, 08:33 »
just got mine, went to fit it but its huge compared to the metal rod
and bigger than the old orange ball.
Is there something stuck in the old ball that i need to switch over?
Offline mk2mark
« Reply #38 on: 26 January 2007, 09:14 »
Yeah there should be a little white insert between the metal rod and the new bush - you can see a pic of it on the page with the installation directions. The fact that it's bigger than the orange ball is good too - tht's the amount of slack that's being taken out of your gearlever!
Breaker
« Reply #39 on: 26 January 2007, 09:22 »
I meant the inside is bigger  :laugh: i can almost fit my thumb in!
i'll have a closer look when i get back. The ball i have now doesnt seem to have
that white part on it? just the orange with a black? insert that didn't come out last night!
