Author Topic: Relay shaft bushes/balls!  (Read 103845 times)
Offline dubslug
Re: Relay shaft bushes/balls!
« Reply #20 on: 17 January 2007, 17:26 »
have also used this on my motor, with a gear repair kit, its all nice and tight now, well worth the money
1992 pearl grey 8v
Breaker
« Reply #21 on: 19 January 2007, 16:43 »
Just placed an order.
Got a gear linkage repair kit as well
1st gear is getting harder and harder lol  :laugh:
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #22 on: 23 January 2007, 17:39 »
still wondering if this will fit the 1.3 linkage, cause it's a ball not the hula hoopy bit on the smaller engines, looky:
but the thign is, te play in mien is in the box, the shift finger below the speedo cable, is where the wobbles coming from  :huh:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
« Reply #23 on: 23 January 2007, 18:21 »
sorry dude its totally different!
sacvwgolf
« Reply #24 on: 23 January 2007, 18:28 »
so where can we buy the the ball thing?
Offline mk2mark
« Reply #25 on: 23 January 2007, 19:47 »
If that ball slips onto a little sleeve then one of my bushes might possibly work? If you want to try out one of my bushes I'd be happy to refund you the £7 if/when you send it back to me. I'd be willing to do that for anyone on here as a matter of fact :smiley:
However, in the time I've been here I've never known rubjonny to be wrong! :laugh:
Offline Ktuludays
« Reply #26 on: 23 January 2007, 21:33 »
got my bush in very quick time, fitting was a piece of piss and now gears are spot on.
you gotta love a nice tight bush for £7
cheers m8
<br /><br />What don\'t kill ya, makes you more strong!
« Reply #27 on: 23 January 2007, 22:45 »
anytihng with a 1.4 engine has them, such as the mk3 1.4s, theyve got the same, and a p reg ibiza in ym scrappy has the same in v good nicker.. tempted to try a swap, afaik theres jut a single screw on the underside and the shift finger can be swapped with he ball intact etc
Quote
« Reply #28 on: 24 January 2007, 11:20 »
the ball is a solid lump o rubber, so to make the relay shaft fit, you would need to chop it out to just the right width.  But even then the shaft bush may not be the right size, and EVEN THEN it wouln't work because the 1.3 ball needs to be round cos it pivots from side to side, and the relay bush you have is square  :grin:
Offline cняis
« Reply #29 on: 24 January 2007, 19:18 »
just ordered a nice tight bush  :shocked:, cant wait to put it on :)
