Author Topic: Central Locking problem  (Read 1286 times)
Offline richjthorpe
« on: 06 December 2006, 10:49 »
Hi all,
I've got a '96 8v GTi.  This morning when I unlocked the car, the central locking didn't kick in.  I've read a few forums on this problem and there are a couple of possibilities.
1. The Padel has broken on the barrel.  Although thinking about it, if this has happened I wouldn't be able to get in to the car at all (Which I can)
2. The Central Locking fuse has gone.  Excuse my ignorance but where is the fuse box on a mk3 golf ? (It's actually the wife's car)
3. The Central Locking pump has gone.  How can I test if it has ?
Thanks,
Richie.
Offline monkeyalan
Re: Central Locking problem
« Reply #1 on: 06 December 2006, 11:32 »
the fuse box is on the right of the steering wheel under the dash. it's a hands and knees job to get too.
Offline richjthorpe
« Reply #2 on: 06 December 2006, 11:35 »
Thanks, I found it in the end after a bit of looking, but non of the fuses are for the central locking.  Is the pump hard wired to the battery ?
Offline monkeyalan
« Reply #3 on: 06 December 2006, 11:45 »
the second one in from the right is central locking,Interior lights, digital clock and fag lighter. should be 15amp
Offline richjthorpe
« Reply #4 on: 06 December 2006, 11:58 »
Cheers.  The interior lights and the clock still work so it's not the fuse.
There are a couple of pumps on ebay, I'll check them out.
Ta, Richie.
« Last Edit: 06 December 2006, 12:13 by richjthorpe »
Offline adyh
« Reply #5 on: 06 December 2006, 13:29 »
Have you felt the pump to see if its working ? Its located in the off side rear boot wall . looks on my diagram like the red/black wire is +12v , brown is earth . The others are just the triggers from the relevant switchs .
Offline richjthorpe
« Reply #6 on: 06 December 2006, 13:34 »
Hi adyh,
Just taken the central locking pump off and there was water in the connection  :sad:.  The pump doesn't do anything.
Haven't tested the power at the moment as I haven't got a tester on me but will try tonight.  Is the fuse that Monkeyalan  described the only fuse to this thing ?
Thanks,
Richie.
Offline adyh
« Reply #7 on: 06 December 2006, 13:41 »
the diagram mentions 2 fuses , A 15amp fuse in what appears to be slot 21 and a 10 amp fuse in what appears to be slot 22 . (no way of checking here at the moment ) pm me your email address and ill send you the diagram .
