Author Topic: broke exhaust  (Read 1960 times)
Offline Danr
broke exhaust
« on: 15 January 2004, 23:45 »
Just got out of work and noticed my exaust was now vertical instead of horizontal, on closer inspection there is a hook on one side which its hanging on and i couldnt see anythin on the other side its dark and wet i gettin on my hands and knees, if the hook is missing do i just replace that or do i need a new exhaust?  :'(
Blue MK2
Re:broke exhaust
« Reply #1 on: 15 January 2004, 23:51 »
ohh mate same here.
On mine a few months ago, the hock that is welded under the car to hold the exhaust had rusted and broke off.
You might have to mig weld the hook back on under the car. Dont drive around like this for too long or your exhaust might crack or fall off.
Then again it could just be a hock has come loose ???
« Last Edit: 15 January 2004, 23:53 by Blue MK2 »
Offline Danr
Re:broke exhaust
« Reply #2 on: 15 January 2004, 23:54 »
Am going to try and get it done tomoro, any idea how much it would cost?
Blue MK2
Re:broke exhaust
« Reply #3 on: 15 January 2004, 23:55 »
probably free. Did you find a broken hook thou?
Offline Danr
Re:broke exhaust
« Reply #4 on: 15 January 2004, 23:57 »
no could of happened on way to work, it was pitch black and pissing it down when i saw it
Blue MK2
Re:broke exhaust
« Reply #5 on: 15 January 2004, 23:59 »
is your exhaust an aftermarket one? probably broke due to the weight, could even be the rubber hanger (hopefully)
Offline Danr
Re:broke exhaust
« Reply #6 on: 16 January 2004, 00:04 »
nope standard
