Author Topic: held back  (Read 1731 times)
Offline Rob
held back
« on: 15 January 2004, 17:19 »
finished work early,her indoors was out so time for a quick blast.
approached nice sweeping roundabout at bottom of hill, in to second, foot to the floor and the b!tch splutterd her way to third, then ok
any ideas :(
Offline workhorse '90 8v
Re:held back
« Reply #1 on: 16 January 2004, 14:16 »
try new plugs,leads,distributor cap,rotor arm  first
Offline Golfgal
Re:held back
« Reply #2 on: 16 January 2004, 16:40 »
join the mk2 judder club m8  ;D
there's loads of us out there....
V5 Beetle owner. I'm just here for the misfire threads....
Offline jedi16v
Re:held back
« Reply #3 on: 16 January 2004, 17:18 »
i had same problem changed leads first and got lucky. no problems after that. i later found out it was just the main ht lead to coil.
                check cap to see it any moisture in it and rotor arm to see if its black where copper colour should be if it is rub it down with fine sandpaper and clean dizzy cap same way. dunno if that is any help. good luck mate.
Offline Dizzie
  • Make friends with your fast
Re:held back
« Reply #4 on: 16 January 2004, 18:18 »
I use to get that in 2nd when I left work. didn't have to be tanking it. just pulling smoothly out of a 90 bend and it'd splutter
