Author Topic: Stiff break pedal  (Read 3565 times)
Offline Paul-GTI
Stiff break pedal
« on: 30 November 2006, 16:10 »
Hi,
Sometines (about 25% of the time) if I have left thr GTI standing overnight or at work, when I return the break pedal feels solid as if it has been pumped, but usually it just has its normal range of motion.
Anyone else have this?
Paul.
Offline The Doc
  • E63s Estate - Vito Sport
Re: Stiff break pedal
« Reply #1 on: 30 November 2006, 18:54 »
It could be your brake assist working...
...if you go from gas to brake pedal real quick the car automatically over assists the brakes to give maximum braking force as it thinks your going to crash!
Does this help?
Offline Paul-GTI
« Reply #2 on: 30 November 2006, 19:37 »
Hi Doc,
Thanks for the reply but it dont really help as its when the car has been standing for  while. I should have made it clear that it happens when you first get in before you start her up,  and it is more likely to happen the longer it stands.
any more ideas?
Thanks, Paul.
« Last Edit: 30 November 2006, 19:39 by Paul-GTI »
Offline dalgleish00
« Reply #3 on: 01 December 2006, 11:57 »
I think mine does exactly the same. get in, put your foot on it and it doesn't really move. Start the ignition and it moves down as normal? I'm pretty sure it is just normal and car kind of priming itself?
05 Pearl Black GTI DSG - most extras
Offline Paul-GTI
« Reply #4 on: 01 December 2006, 12:20 »
Yup, thats exactly it. is yours intermitant like mine, or always stiff? (oo-er!!)
Offline dalgleish00
« Reply #5 on: 01 December 2006, 13:47 »
 :wink: not really noticed - I only drive the car at weekends really. I think if I get in the car and have only been out of it for an hour or so then it is not so stiff (!).
Phil mcavity
« Reply #6 on: 01 December 2006, 15:20 »
surely its bound to be stiff cus the break servo is not being pressure feed from the engine cus its not running, and pedal soffens once the engine starts up and pressurises the braking system, hense why it soffens
Offline Paul-GTI
« Reply #7 on: 01 December 2006, 17:28 »
Sounds logicl, but any idea why it only happens sometimes?
Offline dalgleish00
« Reply #8 on: 02 December 2006, 00:17 »
luckily I don't know how braking systems work or even what a servo is so I assume it is all part of the engineering! :nerd:
Offline 08micsta
  • 1982 Mini 1275 Clubby
« Reply #9 on: 13 December 2006, 09:03 »
Hey all
I know this a GTI Forum. My ma had a Toyota Camry.
Did the same when the engine was off. Toyota told us the reason for this was because of the ABS.
When the engine is on the computer will run the breaks and control how much pressure can be applied. Thats why when you try applying the breaks without the ignition on it will be very tight and stiff because there is no feedback from the computer. If you look on older cars without ABS you can apply the breaks with or without the car running.
Vw SA says that this is normal. If the brakes are still stiff when you start the car and leave it for about 20 seconds then you should consult a dealer.
Hope this helps guys
Mike
The Ultimate Club for Mini Fanatics
Join our group now!
No PAS. No ESP. No DSC. No TCS. No ABS. Just my right foot between me and oblivion. Oh - And a seatbelt.
