Author Topic: Pics of R32 on delivery  (Read 7887 times)
Offline wantmygti
Re: Pics of R32 on delivery
« Reply #10 on: 29 November 2006, 16:45 »
looks awewsome to me. Seats look ace but I'm told they're not comfortable on long journeys?
My only criticism is those plastic floor mats. Sheeesh! Are they delivery mats?
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline Rhyso
« Reply #11 on: 29 November 2006, 17:06 »
looks fecking mint  :cool:
not jealous at all   :rolleyes:
Offline micalee
« Reply #12 on: 29 November 2006, 17:21 »
Yeh mats are delivery mats as this was the day i collected it. It came with fitted VW Mats. Steel Grey i believe is the silver grey colour.
Seats are comfortable, although they are very firm when getting in, but they support you very well. I just prefered the look of the recaros and to tilt the seat forward, you have to lift the the black inserts which are situated in the holes in the top of the seat. Neat function.
Draw back of the 3dr, its a twit to get in and out of the back due to the rear seats sitting back quite far, but this does allow for excellent leg room in back without losing the boot!
MK5 R32 DSG 2006 For Sale soon
Offline Neaty
« Reply #13 on: 29 November 2006, 17:39 »
DSG does come with paddles! Look carefully on picture 3, between the steering wheel and the wiper stalk. Not very clear due to the plastic. Ill have some more photos soon. It has the usual functions of an automatic gearbox, sports setting and slide it over to the left and it goes into tiptronic. Either setting can be over run by another - for example, you can be in drive (normal automatic ) and a flick of the paddle will put you onto changing gears by the paddles. It will also change down and put you into 1st once you have stopped if necessary. Marvelous box.
ah, didnt see them for the plastic around the wheel!
so if you are in tiptronic mode where u are using the paddles, will it change down for you if say u were approaching a juntion and u still had it in 4th if there isnt enough revs?
Offline micalee
« Reply #14 on: 29 November 2006, 17:50 »
OK, in tiptronic mode, the gearstick is slid to the left. This then is operated by tapping forward to change up and tapping down to change down. The gearstick is spring loaded so it returns to the central position after each selection, just like the touring cars!
In this mode, you can over ride it and use the paddles and vise verser. Example for me the other day was, taking a corner whilst using the paddles, i was in tiptronic mode and i wanted to change down. As the steering wheel was quite a bit to the left, it was too awkward to use the paddle to change down, so i used the gearstick by tapping it down.
You can again be in drive mode (usually automatic in most cars) and over ride this and start using paddles.
Reference the changing down, in Drive it will automatically do this for you. In Tiptronic or paddles where you control the gears, it will stay in the gear you have selected until the very last minute! Say your in 6th, your just about to stop, once the revs have dropped due to the speed, it will start to change down as it senses that you would be in the wrong gear should you accelerate!
The gearbox also remembers your driving style! If you drive nice and slow for a few days, it will upshift nice and early, if you on the other hand cane it, taking the revs higher, it will remember this and upshift later in the drive mode.
Hope this helps, any more questions, feel free. I also believe that the DSG changes gear in 5 milli seconds!!, using two clutches, one for 1,3,5 gears and the other for 2,4,6 and reverse (think i have that the right way round!!)
Offline Neaty
« Reply #15 on: 29 November 2006, 17:55 »
thanks, that cleared it up for me
yea they do use two clutches, well as far as clarkson said anyway.  :laugh:
i need to drive one of these direct shift gearboxes to see what they are like
Offline micalee
« Reply #16 on: 29 November 2006, 18:02 »
Honestly, i like the manual, only ever had manual, but after using this, hard to go back. Check out htese videos if you not seen them:
http://www.youtube.com/watch?v=09s8eMLHIUM
http://www.youtube.com/watch?v=WtF6fCFviAo&mode=related&search=
Offline Neaty
« Reply #17 on: 29 November 2006, 18:09 »
just how good do they sound! i bet you never get tired of that  :cool:
Offline TampaGTI
« Reply #18 on: 30 November 2006, 15:03 »
 Flapper open still possible on the new R32 V ?????
Offline micalee
« Reply #19 on: 30 November 2006, 17:29 »
What does this mean???
