Author Topic: Alloys and Lowering  (Read 1361 times)
Offline kt_gti
Alloys and Lowering
« on: 28 November 2006, 10:11 »
At the moment i have a completely standard Golf GTI 8v. I want to put some alloy wheels on it and lower it as well. However i dont want to do any arch work can anyone advise what size alloy wheels and how much to lower it by without any rubbing in the arches? :huh:
Offline Hypermonkey
  • Only users lose drugs!
Re: Alloys and Lowering
« Reply #1 on: 28 November 2006, 10:20 »
I'm running 30/30 drop on Eibachs with 17"s on 205/40/17 rubber.
You can still go over speed bumps without problem and the ride sits sweetly.
If you want a fixed ride hight then shox and springs that are set would be the best answer. I'm just having Wietec ones fitted in a couple of weeks. Wietec also do a great set that is a coilover at the front and an adjustable plate on the back that lets you run from 30mm-90mm!!  This set costs £325 and is very good quality. You could run any size wheel you wanted from 13s-19s as the height is fully adjustable.
Where abouts are you as ----->  http://www.stormdevelopments.co.uk/Contact.html are in Aldermaston nr Reading and are top chaps....they went through what my needs for the car where and what system fitted these and my budget  :smiley:
Offline Len
« Reply #2 on: 28 November 2006, 10:54 »
I run 17's with 215/40 rubber and not lowered at the mo.
With the standard soft suspension I do get some wheel rub on the rear (from the leading edge of the bumper)
So with 205/40 you should be fine lowering.
Any larger wheels than the 17's will require arch work and a speedo recalibration.
www.sas.org.uk
www.the-ace.org.uk
Offline SLIM-DUB
« Reply #3 on: 28 November 2006, 11:08 »
this debate can go on for ever,ive got 17s 215/40s and mines lowered 60mm with no scrubbin!  :wink:
<br www.vwwold.co.uk<br />PIMPASAT 20v se
Mint Finish!
Offline Len
« Reply #4 on: 28 November 2006, 11:13 »
It usually does! :wink: :laugh:
My scrubbing only happens when I get a full load in the back! 2 hefty blokes plus a boot full of luggage! And my old standard springs are going soft. So I'm only guessint that a lowered car may have scrubbing problems.
May also be to do with the offset of my wheels so dont know!
Does anybody know how I can measure my wheel offset?
Good to know from you slim-dub that the same tyres are fine on 60mm drop!
www.sas.org.uk
www.the-ace.org.uk
Offline SLIM-DUB
« Reply #5 on: 28 November 2006, 11:31 »
the only thing that looks like its had done is the camber angle slightly adjusted,still it sits pretty sweet and imo looks the nuts,much more aggressive!  :wink:
Mint Finish!
Offline suzyGTI
« Reply #6 on: 28 November 2006, 12:47 »
im running on 215/40/17s and lowered 60mm on spax shocks and springs.  only scrubbing is fully laden in the back.  the other gti is lowered about 40mm on 205/40/17s and no probs at all with that one (when its running lol)
Free image hosting by http://www.holdthatpic.com/
