Author Topic: Newbie  (Read 23584 times)
Offline Ben-e
Newbie
« on: 09 May 2003, 02:21 »
Hi, im Ben from coventry & am new on this forum.
I have a mk3 8v anniversary in mystic blue.
Just starting to do a few mods, have modified air box & air flow meter & put in a cat replacement pipe (supersprint). Wondering what  to go for next. If im going down the route of cam/head work/chip etc is it best to get it chipped last to make the most of the other mods? I dont want to get it chipped and then do something else only to find i need a re-chip.
Thanx in advance
Ben
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
Offline concept
Re: Newbie
« Reply #1 on: 09 May 2003, 17:43 »
hi ben,
is your engine an AGG? i presume you have read about mods i've done on my 8v? what else have you been thinking bout doing?
i recomend a complete exhaust system - thats where i felt i got the best gain. i'm gonna try some mods for intake soon then i'd like to take the head off for flowing and matching manifolds. i'd probably chip it last as you said.  standard cam has nice torque
so, was airbox and flow meter an improvement? ???
mk3 8v 140bhp
Offline Ben-e
Re: Newbie
« Reply #2 on: 09 May 2003, 21:51 »
Yes it is an AGG
The main thing i noticed from the airbox & airflow meter woz the noise obviously  8) seems a bit more willing at top end now altho i have been raggin it about a bit more since i did those cos its more fun now its noisey! Definately noticed a difference with cat pipe & doin the airbox.
i did the cat pipe the day b4 the airbox so its difficult to tell how much difference the airbox made not being used 2 it with no cat yet.
Other engine mods im thinking of are exhaust system (dont want anything loud tho so i dont know wot 2 go for), cam, chip, manifold work and if i can manage to save a bit of money up then may eventually get onto some head work.
Do most the work maself cos i work at listers vw so that helps the cost a bit heh.
Feel free to give me any suggestions u may have as to mods i can do cos im short of ideas. Not sure wot i can do without messing up emissions to get it through an MOT.
Offline concept
Re: Newbie
« Reply #3 on: 09 May 2003, 22:41 »
i'm getting a bigger bore intake pipe from impossible performance (abd) next week.  :)
have thought about lightning the flywheel.
has anyone done much to fueling on mk3 8v? i tried a fse boost valve but didn't rate it and don't use it no more.
i think it's time to flow the head !
mk3 8v 140bhp
Offline Ben-e
Re: Newbie
« Reply #4 on: 10 May 2003, 18:43 »
There isnt alot of point messing about with the fueling IMO because if u increase fuel pressure, the lamba probe will sense the mixture being too rich and back it off anyway. U will get a rich mixture for about a second when initially putting ur foot down until the lamba probe takes over. So unless u wanna run it richer for around 1 second which isnt particularly worth it i wouldnt bother.
I suppose it would be possible to have a remappable ecu to cater for the lambda probe but gettting it through the MOT would be a right b!tch unless u keep ur old one so u can swap it over when the time comes.
Offline concept
Re: Newbie
« Reply #5 on: 13 May 2003, 00:15 »
ok, good point.
standard fueling is probably ok for up to about 200bhp i guess?
i'd love to get up to about 170bhp !
thats what i'm aiming for. i posted a message asking who else had quick mk3 8 valvers but nout above my 140 !
i'm sure there's a few out there
mk3 8v 140bhp
Offline dlni
Re: Newbie
« Reply #6 on: 13 May 2003, 11:45 »
Ben-e, you mention modifying the air flow meter ... what did u do?
Offline Ben-e
Re: Newbie
« Reply #7 on: 13 May 2003, 21:58 »
Copied what concept did hehe.
Took out the mesh from it. Not sure it makes much difference but every little helps! There is a big circlip holding in the mesh, dead easy 2 take out. And put back in if u ever need to.
Offline dlni
Re: Newbie
« Reply #8 on: 14 May 2003, 12:07 »
Took out the elbow bend, trumpet unit from the airbox to the driver side wing and used a flexie pipe to get the air from the front spoiler.  Also changed the (dirty) air filter, fuel filter, spark plugs, soft and chewing gum like (with holes) sump breather pipe, a leaking engine side wall flange and a coollant change ...  what do the garages do in a service costing from ?160 - ?250?
Noticed the throttle feels nice and free and no more problems @ 2000 revs.
Have had the 8v gti @ 43mpg on a 25 mile journey ... now to see if this all makes a difference.
considering saying goodbye to motorbike and installing a supercharger and a six geared box ... or maybe I'm just dreaming.
Offline sherbert
Re: Newbie
« Reply #9 on: 14 May 2003, 12:29 »
Like the sound of the flexi pipe idea to the front spoiler.
I thought about this at the weekend. Nice to see someones tried it. No unforseen problems with this mod??
mk3 gti 16v silver dream machine (Now has nice wheels :) )
