Author Topic: Water in rear footwell  (Read 1620 times)
Offline GaryO
« on: 14 January 2004, 18:47 »
My Mother drives a mk2 GTI which she has had from new (1985 I think), over the last few months the rear footwell has been filling with water and I can't find where it's coming from. Any one have any ideas? (I don't think it's coming from the sunroof although I would have thought that this is the most likely place).
Gary
Veedubgt18v
Re:Water in rear footwell
« Reply #1 on: 14 January 2004, 18:51 »
the membrane behind the door cards (trims) will be leaking because it shrinkds over time, take the door card off and cut to size a new piece of plastic sheet, i used a builders bag from b+q, and stick it down securely on all sides with waterproof tape/silicone sealant etc. also unblock the drain holes in the bottom of the doors. it is worth doin this on all the doors cos being an 85 model they will all be the same
ed
Offline warne16v
« Reply #2 on: 14 January 2004, 18:54 »
its the door membrains probabley rotted away check the bottom of the door cards if they are damp or you can see a waterline then thats the problem
just had both mine done at a cost of 50quid although you can do it yourself check some earlier threads on what to do this is a very popular problem :)
Blue MK2
« Reply #3 on: 14 January 2004, 19:07 »
quite a cool mother 8)
