Author Topic: Throttle body  (Read 1065 times)
Offline boyob32
  • 1.8T
Throttle body
« on: 24 November 2006, 10:09 »
My car is fluctuating when idle. I have cleaned the MAF and it has improved it however it is still happening...
I've read a few posts and i'm under the impression that cleaning the throttle body may help, is this so???
Also if i were to attempt it do i need to use vag com after re installing?? Again some posts say you need to, where as some don't....??
Offline GOLF_STU
  • THE_GIT
Re: Throttle body
« Reply #1 on: 24 November 2006, 11:09 »
its easy to clean all you do is disconnect the pipe and use some wd40 and a cloth and clean inside the just put the pipe back  :smiley: but i would also check the rocker cover breather pipe for cracks as this is what mine did and the idle was all over the place  :huh:
V TEC KICKED IN Y'ALL!!!
Offline boyob32
  • 1.8T
Re: Throttle body
« Reply #2 on: 24 November 2006, 11:27 »
cheers for that. How much do the breather pipes cost if a replacement is needed?
Offline boyob32
  • 1.8T
Re: Throttle body
« Reply #3 on: 24 November 2006, 11:37 »
Another silly question....there is a clamp fitted to one of the pipes, how do i remove it so that i can re-use it? or do i just have to replace it?
Offline GOLF_STU
  • THE_GIT
Re: Throttle body
« Reply #4 on: 24 November 2006, 14:24 »
the pipe was about £27 but i had to pay £5 extra to get it next day  :sad: i just rerplaced the clips with jubilee clips cause apparently you need a tool to put em back on properly but i just sprung them open with a screw driver bein carefull not to slip lol
