Author Topic: Panel filter Mods  (Read 2018 times)
Offline Camboose
Panel filter Mods
« on: 23 November 2006, 15:20 »
I have a n reg 16v with a panel filter. I have read some threads with regards to altering the air intake pipe. My car doesnt really have nay induction noise, and I would like some more. How do I do this and where do I get the appropriate parts from. Cheers
Offline irmscher
  • Mobile Engine Tuning www.premiertuning.com
Re: Panel filter Mods
« Reply #1 on: 23 November 2006, 16:34 »
Hi mate,
you could make a separate cold air intake but i haven't..
what i have done is remove the airbox, clean it out...then drill some holes in the wing side and front side of the bottom half of the airbox - you don't want to drill holes on the engine side as that is likely to let in hot air which is not good for induction..
Also remove the plastic internal intake pipe coming in from the air feed...mine wouldn't come out even when i pushed the retaining pins in...so i broke it off...
Not sure about performance gains but u'll get much better sound..
Mobile Engine Chiptuning & Remapping Specialists
Cars tuned from £199 at base
info@premiertuning.com or Facebook
Offline Camboose
« Reply #2 on: 23 November 2006, 16:49 »
I opened up the airbox and looked in the bottom half and there is a pipe down there with a flap thing as well. Do I remove this? How does it come off. Looks like it should slide but it didn't!! Cheers
Offline irmscher
« Reply #3 on: 23 November 2006, 19:10 »
hmm not sure about the flap thing, maybe the 16v airboxes are different to the 8v...
someone else should know??
Offline Camboose
« Reply #4 on: 24 November 2006, 14:48 »
Just found out it called a trumpet. Have read mixed reviews whether to remove or not. Has anybody done it? Don't think I'm gonna drill the box yet though. Does anyone know how to get the trumpet out and whether it is actually worth doing. Cheers
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
« Reply #5 on: 24 November 2006, 16:22 »
just remove the air box and slap on a induction kit, my 16v sounds well sweet now and feels a bit more responsive........make sure you hool up a cold air feed! :smiley:
Offline Camboose
« Reply #6 on: 26 November 2006, 18:13 »
Apparantly you can get the same noise without drilling the airbox and adding a K&N. Not sure what to remove though. Its called a trumpet or something. Had a look in the airbox and can't really see what is mean't. Also I've heard that you can change the stock air feed for a aftermarket one. Will this make a difference? I need an idiots guide to modding the airbox!!!
Offline irmscher
« Reply #7 on: 26 November 2006, 20:59 »
Just replacing your panel filter with a K&N Panel won't make any difference to the sound mate.  Drilling the airbox and removing the trumpet will.  You'll get a much throatier sound.
Replacing with an induction kit is another option, but you will definitely need to run up a cold air feed probably from the lower front bumper area.
Just drill out the box, remove the trumpet and pop in a good panel filter.  I'm using a Jetex in ours.
Offline Hypermonkey
  • Only users lose drugs!
« Reply #8 on: 26 November 2006, 21:24 »
I've got a 57i on mine and in the cold it certainly does roar...but do make a cold air feed as it gets very warm, especially in traffic and in the summer. An enclosed system like the CDA is great but expensive.
The power with a conventional induction kit is compromised as the roar sound is actually the air getting uneavenlt sucked in, if you want optimum performance the air should be smooth like in the Pipercross Vortex system.
Saying that...I'm gladly giving a few bhp away as the roar is sweeeeet :evil:
Offline Camboose
« Reply #9 on: 27 November 2006, 10:55 »
Where exactly is this trumpet? I've had a look in the airbox but can't see it!! Is it in the cold air feed?
