Author Topic: Earth straps on a mk1 cab...?  (Read 1746 times)
Offline Mk1cabby
« on: 23 November 2006, 09:44 »
My starter motor wont crank due to the earth straps being either missing or in the wrong places..!! :sad:
Can anyone tell me where the earth straps should go on a Mk1 Cab??
I have one from the earth terminal of the battery which is definately been played about with.
And I believe there should be one to the gearbox so that my starter gets earthed..?? :wink:
Thanking you in advance.
Jason.
[img]
Re: Earth straps on a mk1 cab...?
« Reply #1 on: 24 November 2006, 12:10 »
battery -> battery tray -> bracket on gearbox somewhere
What I'd do is upgrade to late MK2/MK3 earthing, you replace the rear gearbox mounting bolt for one with a stud on the end, and run the earth there.  That should ensure the starter gets a really good earth :)
Offline RIPP3Y
« Reply #2 on: 04 December 2006, 22:27 »
I also have a mk1 Cabby,
  i got a prob with the heater not working, well :undecided:, it works fine for about 4-5 mins then fades away, only to come back to life if i drive over a manhole/ditch/hump.
  Could this also be down to a bad earthing on the car?
« Reply #3 on: 05 December 2006, 10:07 »
I take it you mean the fan?  It may be damaged wiring to the resistor, or the resistor itself is buggered.  Its easy to get to on a MK1, open the bonnet & remove the plastic scuttle cover (carefully!!)
You'll see the fresh air intake grill, remove it then you'll see the blower fan.  It comes out from above though I'm not 100% sure how, check these links:
http://forums.vwvortex.com/zerothread?id=1817057
http://forums.vwvortex.com/zerothread?id=1843162
Offline RIPP3Y
« Reply #4 on: 05 December 2006, 23:18 »
thx for the links rubjonny, i havent seen that vwvortex site before, they give a good clear explanation on how to.....
  When it stops raining i`l give it a go. :wink:
« Reply #5 on: 05 December 2006, 23:30 »
you'll be waiting a while :grin:
