Author Topic: Wont idle  (Read 2293 times)
Re: Wont idle
« Reply #10 on: 22 November 2006, 17:42 »
there isn't one really, the only thing i can suggest is you swap the ecu temp sender with a new one from VW :)
Offline yabbie
Re: Wont idle
« Reply #11 on: 22 November 2006, 21:40 »
if i ran my car on the fault code reader would it pick this up i have it booked in next week ?
Re: Wont idle
« Reply #12 on: 22 November 2006, 23:22 »
it should do, ideally you want the codes cleared then run the car to see what new ones pop up.
Offline yabbie
Re: Wont idle
« Reply #13 on: 24 November 2006, 20:23 »
where can i find this blue temp sensor and is it easy enough to get to any info thanks guys i think i might get a new one in the morning and try and fit.
Offline rob2006
Re: Wont idle
« Reply #14 on: 24 November 2006, 20:54 »
Hi, my mate has an m reg 2.0 8v ,doing exaclty the same thing , altho his oil pressure swich is p155ing out oil also ! ? , the car will sometimes start ok and 5 mins later will start and stall after 1-2 secs , if you floor the throttle it will  idle and run ok until you switch off never lets him down when its running , did you manage to suss out this problem , if so what was it , regards rob (ps great site by the way)
Re: Wont idle
« Reply #15 on: 25 November 2006, 10:13 »
16v ecu sensor isnt blue, I think its white?  Sat on the right side of the block IIRC.  Shouldnt cost alot from VW :)
Offline yabbie
Re: Wont idle
« Reply #16 on: 25 November 2006, 21:54 »
Thanks for the help lads ive got it sorted now trned out to be a snapped cable. Just had the feeling to cut the little rubber thingy open and well what do you know.
        ÂÂÂ
