Well, my VR6 has some electric window issues. No suprise for a Mk3 I know, but I've not seen this particular problem around here...
Anyway, the problem lies with the front passenger window (it's a 5 door). It intermittently stops working, but it seems to only really do it when the weather gets colder. Usually someone will wind the window down, and then it won't go back up. If it was only wound down partially, then it doesn't go down either, so it's like no power is getting to the window or something. If you wait 5 or 10 minutes, then try it, it works. No combination of ignition on/off, car starting, etc with the switch held down or not seems to make it come back to life, it just takes time.
I knew about this problem when I bought the car, but it was fine all through the summer, and has only recently cropped up again now winter's more or less here.
Problem occurs with the switch on the door, and the one on the driver's door so it's not that, and I'm sure that when I looked at this before I checked and you could hear the relay clicking when you pressed the switch, so would that suggest it's not the relay?
Failing any suggestions, if anyone has a wiring diagram for the plug going into the motor/regulator in the door I'd be grateful, so I could at least get the multimeter on it and see which side of that plug the problem is. I've looked about but can't seem to find it anywhere.
Thanks
