Author Topic: Dump Valve for 1.8 turbo  (Read 1439 times)
Offline ian00uk
« on: 10 November 2006, 21:28 »
does anyone know good places to get a closed system dump valve?
i have 1 on my golf at the min which dumps it into the atmosphere but need to change it to one which dumps the air back through the engine?
cheers  :smiley:
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: Dump Valve for 1.8 turbo
« Reply #1 on: 11 November 2006, 10:45 »
Yep, you need the tried & tested Forge recirculation valve.  Have a look at places like www.vwspeed.co.uk & www.awesome-gti.co.uk
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
« Reply #2 on: 11 November 2006, 16:18 »
Offline WOODSIE
« Reply #3 on: 19 November 2006, 14:21 »
hi there,
 if you fit a forge oo7p you will lose that dump valve sound as it is a diverter valve and not dump valve but if u add a carbonio cold air intake or similiar cold air intake you get the sound back!!
if i were you id take your other dump valve off asap as it will cause you enigine management problems
Offline ian00uk
« Reply #4 on: 19 November 2006, 19:59 »
Thanks for you help guys
Offline ian00uk
« Reply #5 on: 22 November 2006, 22:30 »
How does carbonia kit work with a dump valve.does it work with atmospheric one better?
