Author Topic: Rocker Panel  (Read 1112 times)
Offline Import1
Rocker Panel
« on: 10 November 2006, 10:47 »
Does anyone know where I can get a rocker panel new/used aftermarket/oem it doesnt matter...I need one for a 1993 VW Golf GL.
Regards
Offline Greg
Re: Rocker Panel
« Reply #1 on: 10 November 2006, 14:01 »
'99 Mk4 1.8T - FMC007p - R-Tech Stage 1 | '97 Mk3 16v | '91 Mk2 16v | '83 Mk1 L
http://blackgolfgti.blogspot.com
Offline Import1
Re: Rocker Panel
« Reply #2 on: 10 November 2006, 20:23 »
Nothing on those links that I could find...does anybody have a MK3 they are parting out and have a rocker/sill panel?
Offline vwagain
Re: Rocker Panel
« Reply #3 on: 10 November 2006, 22:44 »
Not sure what you when you say "rocker/sill panel?"  :undecided:  Do you mean the actual rocker cover on top of the engine?? If so, id ring all the breakers yards near you and try and find one.  If its the gasket you need, then the links in Gregs post will sort you out.
Stu
1996 2.0l 8v, black magic pearl paint<br />
Offline Import1
Re: Rocker Panel
« Reply #4 on: 12 November 2006, 05:26 »
I mean the panel under the doors, that runs along the jack points.
