Golf mk2
HEADLIGHT PROBLEMS
Topic: HEADLIGHT PROBLEMS (Read 3376 times)
chevychase
HEADLIGHT PROBLEMS
11 January 2004, 20:45 »
can anyone help? i got a mk2 gti 16v 1989, when i turn my lights on there fine but when i put my spotlights on, the passenger side goes off but the side light stays on and if i only use the flasher it stays on but the spotlight doesn't come on
Helios_Blue_Valver
Re:HEADLIGHT PROBLEMS
11 January 2004, 20:57 »
sounds to me like there is a wiring fault somewhere. I know your thinking "No Sh1t" . Try looking around the headlamp wiring and see if any wires have rubbed together and worn the casing causing them to touch. does sound funny though.
chevychase
11 January 2004, 21:03 »
8916vGTI. i've looked and cant see anything. dont you think the fuse would have gone if that would have happened?
jedi16v
GTI forum regular
11 January 2004, 22:22 »
could be an earthing problem
jedi16v
GTI forum regular
11 January 2004, 22:23 »
or a light stalk/switch problem (poor connections)
chevychase
11 January 2004, 22:41 »
now thinking about it, i did wired the spotlights back up with terminal plugs along time ago when i had a little bump and lost the clip. they may have touched, if this is the case what has happened ?
jedi16v
GTI forum regular
Reply #6 on:
11 January 2004, 22:44 »
a little bump ? on the front end ? thats a bugger mate still sounds like somthings shorting disconnect the spots and see what happens.
jedi16v
GTI forum regular
Reply #7 on:
11 January 2004, 22:45 »
or a bulb may have gone in one of the spot lights hence not making the circuit correct .
rustynuts
Here all the time
God is a DJ
Reply #8 on:
11 January 2004, 22:46 »
Look at the fuse again, if its one of the Mk2 originals then it could be the problem. i have just replaced 2 in my fuse box and they were brittle.
chevychase
Reply #9 on:
11 January 2004, 23:03 »
its not the bulb, not the fuse or the headlight wouldn't work but why dose it go out when the spot comes on. it picked my head all day. if the two wires have crossed where would it have fused and why is the tree wires on the back of the headlight?
Golf mk2
HEADLIGHT PROBLEMS
