Author Topic: Idleing  (Read 2162 times)
Offline jettaTx
  • Mk1 16v + Mk2 G60 + 309 Goodwood Mi16 + Jetta 16v!
Idleing
« on: 11 January 2004, 19:21 »
Can anyone tell me what a mk11 16v KR engine should idle at?? Rpm??
Mine seems a little high i might be wrong??
Blue MK2
Re:Idleing
« Reply #1 on: 11 January 2004, 19:32 »
If you want to adjust it yourself, do you know about the hidden MFA function mentioned before?
goes like this...
Switch the ignition on, hold the MFA button in,
Switch the ignition off (still with MFA button held in),
Keep it held in, now start the engine.
This then enters you into the hidden MFA function :D
Scroll through the function and you will find your engine idle speed.
Use this display to adjust the idle maybe?
Veedubgt18v
Re:Idleing
« Reply #2 on: 11 January 2004, 20:05 »
this isnt a real time display i didnt think  ??? i would go from the rev counter if fitted (should be) i think the idle speed is 850 +/- 50. dont quote me tho   :)
Offline Helios_Blue_Valver
Re:Idleing
« Reply #3 on: 11 January 2004, 20:59 »
sounds right. Thats about where mine idles at.
Offline Gambit
Re:Idleing
« Reply #4 on: 12 January 2004, 09:31 »
16v's are 950/1050rpm
golfvr6
Re:Idleing
« Reply #5 on: 13 January 2004, 09:25 »
i think it should be about 950+-50
Offline jedi16v
Re:Idleing
« Reply #6 on: 14 January 2004, 23:04 »
i think vr6 is right . mine idles between 950 and 975 rpm
golfvr6
Re:Idleing
« Reply #7 on: 14 January 2004, 23:05 »
thanx  :-*
Offline jedi16v
Re:Idleing
« Reply #8 on: 14 January 2004, 23:08 »
ahh aint that sweet  :-[. :-* back at yah
