Author Topic: 95 gti ABS  (Read 2389 times)
Offline GTier
95 gti ABS
« on: 11 January 2004, 19:13 »
Does anyone know where I can get Vag-Com fault codes. I have read the ABS fault code using the shareware but now can't translate. The codes are 00532 and 00285. I suspect a wheel sensor but which one? ???
Offline adyh
Re:95 gti ABS
« Reply #1 on: 12 January 2004, 10:55 »
Ok i've had a look on the internet and have found this
ftp://ftp.artech.sote.pl/ftp/OBD2/vwcode.PDF
it gives the following info
00285 P1716 ABS Wheel Speed Signal #2 (Right Front) Range/Performance - G45
00532 P1746 Transmission Control Module Relay - Supply Voltage (B+) Malfunction Low Battery or Bad Ground
Hope that helps !!!
Offline GTier
Re:95 gti ABS
« Reply #2 on: 12 January 2004, 16:57 »
adyh.
Thanks for the info. Is the web address you posted correct? Can't seem to find the site!
Offline GTier
Re:95 gti ABS
« Reply #3 on: 12 January 2004, 17:17 »
adyh.
Offline adyh
Re:95 gti ABS
« Reply #4 on: 13 January 2004, 12:40 »
