Author Topic: remote door  (Read 1301 times)
Offline modge
remote door
« on: 05 November 2006, 17:37 »
hello again everyone i seem to be haveing a problem with my 1998 golf gti non turbo i changed the stereo to a after markit alpine and now my remote locking doesnt seem to work and the passenger door goes mad when i try to lock it can anyone give me any help with this as its driveing me mental thanks danny
Offline modge
Re: remote door
« Reply #1 on: 05 November 2006, 23:00 »
hello again after reading lots on the internet tonight i got funny colours in my eyes but i have found out that its someting to do with the way the stereo is wired up can anyone tell me what iv done wrong the origanal gamma has a cd changer and the alpine i put in came out of a mk3 vr6 and the plugs looked right and it works but the remote locking is gone can anyone shed a bit of light on this thanks dan
Offline PaulMK4GTI
Re: remote door
« Reply #2 on: 06 November 2006, 13:54 »
You and me both sunshine. Exactly the same happened to me, replaced the gamma with an Alpine unit and the remote locking no longer works, you'll probably also notice that the buzzer that tells you you've left your lights on when you open your door no longer works either. It's not much of a problem for me cause i've got an aftermarket CAT1 alarm/immobilizer on it anyway so i still get the remote locking from that but it still annoys me.
I've looked everywhere for an explanation but can't find the answer, i've read of others having the same problem but also loads of people have replaced their head unit (even with Alpine ones) with no problems what so ever.
I was speaking to a guy at a garage last week and he said he thought it was something to do with the fact that all the various systems on the car are linked together and replacing the head unit upsets this - something to do with the stereo having a diagnostics connection? This could all be complete b*ll*cks mind!
I don't know if re-setting the convenience ECU with VAG-COM would do any good? Maybe someone could shed some light on that?
As for your passenger door going crazy - that could be a seperate issue. Does your door lock then unlock immediately? Has the interior light and door light stopped working when you open the door? If so, it's probably the door lock mechanism - common fault on this car. There's a DIY guide on how to fix it on this forum.
If you get the stereo thing sorted or if anyone else knows the answer let me know cause i'm stumped!
Offline modge
Re: remote door
« Reply #3 on: 08 November 2006, 13:06 »
its the remote aerial wire coming out the stereo take it out and put it so it conects to the other blue and white wire mines all sorted now
Offline PaulMK4GTI
Re: remote door
« Reply #4 on: 09 November 2006, 13:40 »
Cool, i'll give it a try.
Just to check - did you connect the BLUE wire from the stereo to the blue and white wire of the car harness
or
did you connect the BLUE AND WHITE wire from the stereo to the blue and white wire of the car harness?
On my stereo the blue wire is for a power aerial and the blue and white one is to turn an amp on.
The only reason i ask is i thought i read somewhere that you're not suposed to connect the power aerial wire to anything else? Could be wrong though.
Cheers.
