Author Topic: Idle problems, any ideas?  (Read 1868 times)
Offline OP
« on: 11 January 2004, 13:43 »
I'm still having idle problems with my 91 Golf Gti 8v. When I start the engine it idles fine then if I rev it slightly the revs just drop out and it cuts out. Also when I rev it before the stall it'll kinda miss fire on the first 1000rpm and pick up after that, probably all the same problem.
I replaced the idel valve not long back and it buzzes with the ignition on. Also replaced the dizzy cap and arm.
Any ideas welcome as I need to get it MOT'd soon.
OP
http://www.dubberware.com "Personalise Your Ride" Stickers, Clothing Etc.
Blue MK2
Re:Idle problems, any ideas?
« Reply #1 on: 11 January 2004, 13:51 »
adjust the idle screw? ???
Offline OP
« Reply #2 on: 11 January 2004, 13:53 »
Hmmm well it idles fine when first started. It's not until I rev it that it drops. It was running fine the other week when I went up country.
OP
