Author Topic: Driver's door lock broken  (Read 798 times)
Offline wazzag
« on: 02 November 2006, 09:10 »
Hi,
I can't open the driver door using the door handle - it opens however from inside. I think it's just a case of the door handle becoming detached but cant work out how to get the handle out to reattach it (I think i've done this already about 4 years ago!). I've undone the bold directly in line with the mechanism on the door's edge but this seemed to do nothing!
Please help!
Offline Mr Blue
Re: Driver's door lock broken
« Reply #1 on: 02 November 2006, 09:26 »
what car mate?
if its a mk2 then there is another screw under the handle cover
Offline V_Arse6
« Reply #2 on: 02 November 2006, 10:38 »
If it's a Mk3 then after undoing the screw (it's a torx one IIRC) which I think you're referring to should let you slide the whole handle forward (towards the front of the car), and then fiddle around and it should come out fairly easily. There's a vertical bar that goes down to the latch mechanism which should sit in a slot in the handle.  If that's come out, or the 'slot' has broken then I guess you'd have this problem.
It is a little fiddly though.   :undecided:
'95 Mk3 VR6
FK Highsports, Crystal Clear Fogs/Indicators/Repeaters, Mk4 Style Headlights, PiperX induction, Bonnet lifters. (Need to update pic for new headlights)
