Author Topic: Non Vw Question  (Read 1035 times)
Offline Tornado
Non Vw Question
« on: 31 October 2006, 16:36 »
Hi there
Sorry to bring up Vauxhall. But my son ha a 1.2 Nova which has been nicely modified ie subtle sort of eurofied. It has a digital dash and just recently the indicator relay has started buzzing noisily.  The noise stops when you put the indicator on!!  Oddly, the little green light on the dash which shows that the indicator is on did not work before the buzzing started but now it is. Can anyone help?
Thanks
Alan
Lower!
Re: Non Vw Question
« Reply #1 on: 31 October 2006, 17:20 »
I had this exact problem when my indicator stalk failed, the relay would randomly click like a machine gun when indicating left  :grin:
Offline Tornado
Re: Non Vw Question
« Reply #2 on: 31 October 2006, 17:33 »
You think I should try a new relay?
Lower!
Re: Non Vw Question
« Reply #3 on: 31 October 2006, 17:41 »
worth a go as its the easiest thing to swap.  If you have a seperate hazard switch try swapping that too!  Faling that get a new indicator stalk on there.
On my MK2 since its a late one the indicator & hazard stalks are built into the same unit :)
Offline Thom89
  • Looking for an "Icebreaker"
Re: Non Vw Question
« Reply #4 on: 01 November 2006, 00:05 »
Relay sounds good starting point, also check that all the rear lights are operating correctly! could be a bad earth, look in the boot for the brown wires that earth to the rear panel, make sure they are clean and tight..
Alarm and/or immobiliser could be starting to play up..
Tom
Offline Tornado
Re: Non Vw Question
« Reply #5 on: 01 November 2006, 00:36 »
Cheers Thom
I will check the earths that is a possibility. I don't have alarm so cant be that.
Ta
Alan
Lower!
