Golf mk2
8v gearbox
Topic: 8v gearbox (Read 1244 times)
Bear
8v gearbox
30 October 2006, 21:13 »
Are all 8v gearboxes the same ??
Uruk Hai
Re: 8v gearbox
30 October 2006, 21:15 »
As far as I know I think they're all the "020" type but I'm not certain
Agreeable Slick
Global Moderator
Serious forum addict
Unit
Re: 8v gearbox
31 October 2006, 01:05 »
Ratios. No.
Gearbox Codes. No.
Physical design. Yes. (unless it's a synchro or G/Rallye box.)
I made this : ->
https://www.golfgtiforum.co.uk/index.php?topic=30416.0
Gambit
Forum addict
Re: 8v gearbox
31 October 2006, 11:33 »
this will give you a list of all ratio's for all 020 gearboxes by code
http://www.scirocco.org/gears/
Bear
Re: 8v gearbox
31 October 2006, 21:20 »
Thanks guys
How can i tell then if a box will be the same ?? Found an 8v being broken, same year as mine ... is that enough to go on, or anything else i need to check.
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: 8v gearbox
01 November 2006, 08:10 »
If its an 8v gearbox it will fit straight on and work. Only difference will be the ratios! Best to check it is actually a GTI gearbox, at this age its likly its had a new one in its lifetime. If you crawl underneath and check the codes etched onto the flat area on the bell housing as per:
http://www.golfgtiforum.co.uk/index.php?topic=44363.0
The one commonly fitted to 8vs is the ACD box
Bear
Re: 8v gearbox
Reply #6 on:
01 November 2006, 19:04 »
Spot on ... thanks mate
Golf mk2
8v gearbox
