Author Topic: Leak from fan thermo swicth  (Read 788 times)
Offline Uruk Hai
« on: 30 October 2006, 12:20 »
As above does anyone know if the switch has some sort of gasket to seal it or does it just screw into the radiotor as mine is leaking coolant from it and I wondered if it can be cured or do I just need a new rad fan thermo switch, thanks  :wink:
Offline NewStu
Re: Leak from fan thermo swicth
« Reply #1 on: 30 October 2006, 14:43 »
Yeah it has a green fibre type washer/gasket. You could probably just seal it up with some plumbing sealant.
Offline Uruk Hai
« Reply #2 on: 30 October 2006, 21:03 »
Thanks Stu you just saved me buying a new one !
