Author Topic: Help required  (Read 1729 times)
Offline Gozza
Help required
« on: 29 October 2006, 15:34 »
Hi all,
Recently I got into my mark 2 16v on a 1990 and it would not start. It had been really struggling to start before this and when it went I assumed it was the starter motor.
Fitted a new one today (well second hand, was tested and worked apparently) and still the same problem. I am getting a clicking sound from relay 67 in the fuse box and also a clicking from the distributor. I took the cap off and used a circuit tester and there is a spark coming from the middle thingy in the cap about once ever 2 seconds or so. Also the dash lights up the oil battery and temp lights and again they flash in line with the clicking ???
Anyone got any ideas ?
Thanks in advance.
Offline J.stafford16v
Re: Help required
« Reply #1 on: 29 October 2006, 15:49 »
The clicking noise is the solaniod on the starter, give it a smack with a piece of wood and a hammer. If it then starts after that motor is sh*gged aswell!!! :angry:
Offline Thom89
  • Looking for an "Icebreaker"
Re: Help required
« Reply #2 on: 29 October 2006, 15:54 »
Did you check battery condition? are all terminals tight?
Tom
Offline shaft69
Re: Help required
« Reply #3 on: 29 October 2006, 15:58 »
Sounds like duff battery to me mate!!
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline turbodub
Re: Help required
« Reply #4 on: 29 October 2006, 16:11 »
I concur.
Offline Gozza
Re: Help required
« Reply #5 on: 29 October 2006, 16:11 »
Thanks for the quick replies.
I am unsure on the battery as was fitted when I bought it although all the terminals seemed tight at the time. When I bought the starter motor it came with the black thing on the side too so have replaced whole lot.
I thought it might be something to do with the earth I have heard a bit about before, where if trying to start and it starts badly it may be the earth to the gearbox or summat. Anyone know what this looks like/where its located ?  I can then take my working battery from my other car and try that if still does not work.
Again thanks in advance all.
Offline turbodub
Re: Help required
« Reply #6 on: 29 October 2006, 16:23 »
The earth is on the gearbox bellhousing. Follow the thick braided cable from the battery negative terminal and you should locate it quite easily. Try charging your battery and see if it makes a difference, might also want to check your alternator connections while you are there.
Offline Simpson
  • one day il learn
Re: Help required
« Reply #7 on: 29 October 2006, 17:46 »
aye thats sounds right check all earths to battery, and check charge with a mulitmeter  :smiley:
i must buy a new car!
Offline Gozza
Re: Help required
« Reply #8 on: 29 October 2006, 20:29 »
I will give this a go.
Out of interest, if it was the battery wouldn't the car just be very slow to turn over and then die ??
I hate the electrics on cars, always so many things that can go pete tong.
Offline turbodub
Re: Help required
« Reply #9 on: 29 October 2006, 22:05 »
No it won't. If the voltage drops below a certain level then the starter solenoid cannot activate and the starter will not turn at all.
