Author Topic: No heat from heater  (Read 2032 times)
Offline T_J_G
No heat from heater
« on: 29 October 2006, 12:04 »
mk2 Gti 8v PB G reg
No heat from heaters, the car doesn't have a 'stat in, as wthere wasnt one when i bought it,and after replacing it, it kept pissing water out the header tank.
 And when we tried we broke the waterpump aswell :grin:
Got a new stat to put in,are these problems related?
Tim
Offline T_J_G
Re: No heat from heater
« Reply #1 on: 29 October 2006, 13:43 »
update
reaplced stat..runs brilliant for a while..turn it off and it pisses all the water out the overflow part of the water header tank.
 :angry:
Offline Uruk Hai
« Reply #2 on: 29 October 2006, 14:27 »
What do you mean by overflow part ?
Offline turbodub
« Reply #3 on: 29 October 2006, 14:36 »
Sounds to me as though the screw on cap on your header tank may be dodgy. You may also need to bleed and refill the coolant, run the car up to temp with the header tank cap off and the heater controls right over to the hot side, check coolant level when the stat activates and the bottom rad hose becomes warm. You could squeeze the pipes as well at this point, you may be suprised by the amount of air which escapes through the header tank.
Offline T_J_G
« Reply #4 on: 29 October 2006, 14:44 »
The bit where if you put to much water in it overflows....is this the correct tank?
I'll try the screw top off my old Driver..
Offline turbodub
« Reply #5 on: 29 October 2006, 14:48 »
Quote
Quote
That is the header tank. That should be filled to between the MIN and MAX marks on the bottle :)
Offline Uruk Hai
« Reply #6 on: 29 October 2006, 15:38 »
As above the header tank or expansion tank is the plastic tank that sits in the rear right hand corner of the engine bay and it sounds as though you mite be over filling it, it would be worth trying a different tank cap as they can fail and then the system wont pressurize properly. If you've got the heater by-pass valve on yours that could contribute to the heater not being warm as it restricts the amount of water flowing through the heater matrix.
Offline T_J_G
« Reply #7 on: 30 October 2006, 16:05 »
i know what the header tank is... :cool:
its got a hole in the side that acts as an overflow (like in a sink or bath..) sonmdering if it's the right tank  :huh:
Offline T_J_G
« Reply #8 on: 30 October 2006, 16:12 »
oh and when running with stat IN the coolant light flashes then when turned off it pumps the water out..
« Reply #9 on: 31 October 2006, 09:39 »
get a new cap, it sounds liek the seal has failed so either its venting pressure too soon, or not at all!
From what you describe you have the later round header tank, which have a funky overpressure design which vents coolant away from you and down, rather than the older tank which would just spray it everywhere :cool:
