Author Topic: Question about lowering  (Read 2895 times)
Offline Burnsy
« on: 10 January 2004, 12:12 »
Been thinking about lowering my Golf and was wondering what coilovers are ?
Whats the best to use i.e spax etc ?
Thanks in advance
golfvr6
Re:Question about lowering
« Reply #1 on: 10 January 2004, 14:31 »
coilovers are adjustable macpherson struts.
Offline Terminator
« Reply #2 on: 10 January 2004, 18:22 »
I've read that Bilstein PSS9's are really good but expensive and Koni's seem to get good press.
GTi PD150, Revo'd, Hasta La Vista!
Offline S11EPS
  • No golfs here. Only a C63 mercedes
« Reply #3 on: 10 January 2004, 23:48 »
Coil overs are a spring and strut package in a single unit. They offer a considerable amount more adjustment than a conventional spring and damper set up.
In terms of the effect it has, its nothing short of incredible.
I have a buddy running a Skoda Octavia (essentially the same chassis set up as the Mk4) and it is without doubt the best handling front wheel drive car I have ever driven.
Do it, you won't regret it!  ;D
The greatest leveller of them all - the Carousel
Offline red16v
« Reply #4 on: 11 January 2004, 13:39 »
.. and if you do 'do it' don't forget to inform your insurance company otherwise your insurance will be null and void. Ask for an updated insurance quote before you do the work. Regards, yt.
Offline GaryM
  • Gary
« Reply #5 on: 13 January 2004, 17:38 »
I have Koni Coilovers on my Mk4 GTi and they really are good, though one problem I have hit it the front ARB is now catching the driveshaft - this would happen with any method of lowering if you go too far down. Generally the Golf Mk4 only likes to be lowered up to 45mm, after that there's a good chance of the front ARB coming into contact with the driveshaft.
There is a was around it which involves changing the ARB for an uprated one with larger hoops at either end allowing the car to go much lower without contact.
A picture below shows where my ARB has come into contact with the driveshaft
2003 (53) GTI 180  | Custom Code Phase1 remap (JBS)  | Click for photo's and spec
