Author Topic: Power drain!!  (Read 991 times)
Offline Lee Watson
Power drain!!
« on: 27 October 2006, 13:07 »
Hi
Well I’ve finally sort out all my idling problems  :laugh: when along comes winter.  :undecided:
I have notice that since I has got darker the idling has not been so good it works out that when I turn my lights on the revÂ’s drop by about 150-200Rpm & sometimes stalls at junctions.
Has anyone had the same problem? Or any ideas where I should start looking?
Lee
P.S I have a MK2 golf GTI 16v 1990
Offline Uruk Hai
Re: Power drain!!
« Reply #1 on: 27 October 2006, 13:21 »
Get your alternator checked and for the stalling check the vacuum pipes for splits also you could check and clean the idle stabilization valve.
Offline Jonp
Re: Power drain!!
« Reply #2 on: 27 October 2006, 13:23 »
Hi Buddy,
The first thing i'd check would be the state of your fan belt (i'm not sure if you have a serpentine belt or a fan belt as found on 8v's):
Tighness etc.
The second would be the voltage that the alternator is putting out... at a guess around 14 volts.
best of luck!
Offline Lee Watson
Re: Power drain!!
« Reply #3 on: 27 October 2006, 13:29 »
Thanks guy's I will have a look at it over the weekend.
Lee
Offline NewStu
Re: Power drain!!
« Reply #4 on: 27 October 2006, 14:04 »
The alternator is no doubt the source of the problem so get it checked out to make sure it is putting out enough power. A work around however may be to get an uprated headlight loom which takes its power direct from the battery and will stop stealing it from the engine. This wont be a propper fix as the battery will no doubt start to fail after this.
Offline Bluefox
  • ...back again!
Re: Power drain!!
« Reply #5 on: 28 October 2006, 23:28 »
I'd get the battery checked as well - it is probably the altanator as discussed, but sometimes a knackered battery can make strange things happen.
Bluefox
Current: '84 Golf C 1.9 TDi | '01 Polo GTI | '01 Audi A2 TDi | '83 MG Metro
Previous: '83 GX | '04 R32 | '93 VR6 | '86 GTi 8v | '88 Diesel | '92 G60 | '04 Skoda Superb TDi | '90 GTi 8v | Plus many more!
Project Thread - http://www.golfgtiforum.co.uk/index.php?topic=270683.0
