Author Topic: small vs big airbox 16v  (Read 845 times)
Offline Diluxe
« on: 25 October 2006, 18:52 »
wanted to replace my air mass flow meter, so bought the complete kitt with airbox and rubber connector upto the throttle body of ebay.
But................. i just noticed that the air box is bigger than my 89 16v box, and there seesm to be one or two extra connections, will it all connect upto my original system (vacuum pipes etc) or does it need to go back on ebay?
cheers
1997 16V
Offline Gambit
Re: small vs big airbox 16v
« Reply #1 on: 26 October 2006, 09:37 »
just take the air mass meter off and use your existing box & pipe setup
Offline Diluxe
« Reply #2 on: 26 October 2006, 12:11 »
is there any advantage in using the latter set up, vw must of changed over for a reason????
1997 16V
Offline Gambit
« Reply #3 on: 26 October 2006, 15:50 »
there is no power advantage or the likes of that
AFIAK the reason was a new parts bin i.e. cheaper to make a 4 sided box rather than one with a big horn on one end!
