Author Topic: coolant  (Read 960 times)
Offline gtitdi
coolant
« on: 25 October 2006, 17:38 »
i drained my radiator this afternoon (took off the bottom pipe) and when I refilled it i only got about 2.5 litres in before it was full - i see that the haynes manual says 6.3 litres - where is the extra coolant?! does it not all come out when the radiator pipe is removed? thanks in advance
Re: coolant
« Reply #1 on: 26 October 2006, 13:52 »
inside the engine block, unless you take out the thermostat it will be full of coolant :)
Offline yabbie
Re: coolant
« Reply #2 on: 27 October 2006, 16:15 »
Had that happen to me had to flush out the radiator cause i think it was blocked when i filled it up i only got about 2 liters in what i did is pulled the top hose off the rad to allow the air to escape until the coolant started to run out the top. then i close it back up left it over night (got to dark to work) saw the coolant had gone down then just topped it back up good luck.
« Last Edit: 27 October 2006, 16:17 by yabbie »
