Author Topic: I might cry!  (Read 1045 times)
Offline golfmk2boy
I might cry!
« on: 25 October 2006, 15:02 »
So I took today off work to try and get my car finished.
I thought everything was done, tried to start it the other night however I could only hear the fuel pump working.
Thought at first it might have been an earthing issue, so I made sure that earth leads were ok.  Tried to start up again and smoke started coming out near the speedo, then all lights on the dash went out!... so I think I have fried the ignition wires??
I then looked again in the engine bay and could see a contact that has no connection to it on the starter motor. DUH!!!! Im so stupid!
Looked on laptop (foto below of old engine) for the connection within the engine bay, but cannot find it anywhere!!!.... where is this connection and which side of the engine bay does it come from.  I have checked three times or more, but cannot find it!
 :cry: :cry: :cry: :cry: :cry:
« Last Edit: 25 October 2006, 15:04 by golfmk2boy »
Offline tobz.
Re: I might cry!
« Reply #1 on: 25 October 2006, 15:18 »
I'm pretty sure that wire you have highlighted is the main 12v feed to the starter in which case it would go directly to the +ve terminal on the battery.
You got any pics of your dad's split ?
Re: I might cry!
« Reply #2 on: 25 October 2006, 16:13 »
That is the trigger wire to the starter, which runs from the rear of the fusebox out of the engine loom near where all the sensor wires are.  Its a chunky red/black wire!
Offline golfmk2boy
Re: I might cry!
« Reply #3 on: 25 October 2006, 16:16 »
I already have connection from battery to starter connected (the two  "O" rings).
It is the top "male" connection that is the problem?
Offline golfmk2boy
Re: I might cry!
« Reply #4 on: 25 October 2006, 16:29 »
I just cant find that connection to the "mail" connector
Would anyone be able to take a picture of the starter motor and where the lead comes from?
Im willing to pay £5 paypal.
Re: I might cry!
« Reply #5 on: 25 October 2006, 16:55 »
just leave it, you don't need to have it connected on a Digi MK2 :)
Edit: you could try plugging the spade plug you have onto the other terminal ;)
Offline golfmk2boy
Re: I might cry!
« Reply #6 on: 25 October 2006, 17:01 »
What's it for though?
Re: I might cry!
« Reply #7 on: 25 October 2006, 17:21 »
Its for 16vs I believe, they have a seonsor or something plugged into it :)
