Author Topic: Ignition Coli  (Read 694 times)
Offline AW
Ignition Coli
« on: 25 October 2006, 09:52 »
Since changing the ignition coil on my Mk2 16v the fuel pump fails to run. Can anyone confirm to me the correct connections to the coil please?
Offline takethefifth
Re: Ignition Coli
« Reply #1 on: 26 October 2006, 01:26 »
Hi, the coil connections are simple, the centre HT lead to the dizzy and then a battery live and an earth which should be marked on the coil.  I don't think this would have any bearing on your fuel pump not running. More likely a knackered fuse, wiring or pump.  :smiley:
Offline AW
Re: Ignition Coli
« Reply #2 on: 26 October 2006, 09:25 »
Sorry for being a bit thick but got the battery live connected. What kind of connector is the earth or what does it look like?
