Author Topic: Fuel Pump Fuse  (Read 1472 times)
Offline M41K1T
Fuel Pump Fuse
« on: 24 October 2006, 13:09 »
Hi
Have problem with my fuel pump fuse, everytime i click onto ignition the fuse blows, any ideas on how to resolve?
Offline gibby
Re: Fuel Pump Fuse
« Reply #1 on: 24 October 2006, 13:53 »
Check there's no dodgy wires touching somewhere on the fusebox that it shouldn't be. This maybe really obvious, but are you using the correct fuse ? i.e. is it a 5 when it should be a 15 ?
Does this site help at all ? http://dana.ucc.nau.edu/~kaw5/electrical.htm
......now officially dubless.
Offline Mk1Mad J - 16v
  • At my age I don't have to act responsibly...
Re: Fuel Pump Fuse
« Reply #2 on: 24 October 2006, 13:56 »
Sounds like the fusebox has got wet  :sad: y.  Did it start doing it when the rain started?  - do a search in the mk1 section as this subject has been covered loads as its very common with mk1's unfortunatly, along with cr@p brakes - but a small price to pay to drive the greatest car ever built  :smug:
Ideally you need to find the leak(s) and stop them or the rest of the electrics will soon follow suit  :sad:
In the meantime you have 2 options:-
1:  bypass the relay on the relay plate with a wire between 2 terminals  :embarassed: I forget which but someone else here will no doubt know  :wink:
2:  not reccomended but it works  :wink:, run a switched live feed to the yellow/red wire thats behind the fusebox (theres 3 wires going into a terminal, one is from the fuse box, replace that one.  You need to make sure you turn it off when the car is off as the fuel will pump continuously :smiley:
"Ever since I started to surf, I have realized that golf is for people who don't know how to surf."  -- Tiger Woods.
my dub project:-
http://www.golfgtiforum.co.uk/index.php?topic=35338.0
http://www.youtube.com/watch?v=WyEUOoH_xxo
