Author Topic: Urgent Help Needed  (Read 1748 times)
Offline Slim
Urgent Help Needed
« on: 09 January 2004, 13:12 »
Just got home from college, and there's smoke p!*sing from my passenger side brakes, going for about 5 minutes, I threw some water on it and it all steamed up and started hissing like mad. Still smoking now after 15 minutes. The engine block is hot too as is the collant tank so I took the cap off that and that let out steam too although the water wasn't bubbling. Just had it a week, don't fancy it blowing up, anyone know what's wrong or what I should do? The smoke seems to be coming from behind the brake disk.
Offline danhock
Re:Urgent Help Needed
« Reply #1 on: 09 January 2004, 13:16 »
Sounds like the pads are locking onto to the disc, probably on the inside pad.... Maybe a sticky caliper..
Let it cool down and take it off to have a look.
May need a new caliper or you can recondition it yourself (if you know what you're doiing)
All opinions expressed in this mail are wholey owned by danhock and are not representative of golfgti.co.uk or it affliates.If you disagree with my comments please note that i do not give a f**k ?2005
Offline Helios_Blue_Valver
« Reply #2 on: 09 January 2004, 21:09 »
sounds like the typical mk2 parking brake sticking on. My driverside rear was doing it. pulled it apart and rebuilt it. problem solved. :)
turbo
« Reply #3 on: 10 January 2004, 02:34 »
sounds right! nothing else would cause smoke to come from the back wheels unless its being handbraked!!!!!!
