Author Topic: Oil leak??  (Read 1006 times)
Offline dubpolo1
Oil leak??
« on: 24 October 2006, 12:14 »
i own a mk2 8v gti, (digifant) and there looks like a oil leak coming from the rocker cover gasket and down towards the spark plugs (if u know which part i mean). So is this a common problem i.e serious??
Anything i should do myself or just take to a garage to put right?
Cheers for any info, much appreciated.
Offline Agreeable Slick
  • Unit
Re: Oil leak??
« Reply #1 on: 24 October 2006, 12:51 »
Change the rocker cover gasket, and torque them up right, they don't torque to much.
Offline Mart8V
  • I really should know better by now.....
Re: Oil leak??
« Reply #2 on: 24 October 2006, 13:14 »
Very simple change.  10mm socket, the kit from VAG (don't get the GSF one) and make sure you change the studs as well.
Took me about 45 mins all in, and I'm no speedy worker!
And yes, very common!
Offline dubpolo1
Re: Oil leak??
« Reply #3 on: 24 October 2006, 13:15 »
how does a rocker cover gasket usually cost? any reason why my one needs replaced
  • Unit
Re: Oil leak??
« Reply #4 on: 24 October 2006, 13:28 »
about £6, and yes, it's made of rubber, oil + rubber = the rubber breaks down over time. Nothing to worry about.
Offline dubpolo1
Re: Oil leak??
« Reply #5 on: 24 October 2006, 13:31 »
cool thanks slick
Re: Oil leak??
« Reply #6 on: 25 October 2006, 13:26 »
it may have a rubber gasket already, check the studs.  If they have a shoulder they are for the older cork gasket and shoulf be changed, if not they are for the new rubber type and you can leave em alone.
Either way, buy the repair kit with the studs included from VW, as its cheaper than buying the gasket on its own  :grin:
