Author Topic: Has anyone got and used VAG-COM ?  (Read 2342 times)
Offline 2007GTI
« on: 24 October 2006, 11:45 »
Someone on another posting mentioned VAG-COM.  I just wondered if anyone has it, as it looks like you can buy the required cables/connectors easily and get the shareware software required to run on a PC.
Obviously it could be handy, but I wondered if its worth the hassle?
Offline Rhyso
Re: Has anyone got and used VAG-COM ?
« Reply #1 on: 24 October 2006, 12:06 »
I've only got the shareware version but its a useful tool for checking fault codes etc.
check out www.ross-tech.com for further info.  You can get the leads and full software from them for around £200.
If you have to take your car to the dealers they'll charge you a minimum of £70 to hook it up.  Go 4 times and you just as well buy VAG-COM!
I've used the shareware to read fault codes and also test my MAF - you can do real-time data logging; it measures things like coolant temp, air flow, RPM etc.
Offline 08micsta
  • 1982 Mini 1275 Clubby
« Reply #2 on: 24 October 2006, 14:26 »
I looked at the site and I noticed you could download the program.... And buy the cabkes later....
But there are two options.
USB or HEX????????
The car is a 2006 Golf GTI in specific. What system does it use?To connect tot eh pc??
Pls help
THX
The Ultimate Club for Mini Fanatics
Join our group now!
No PAS. No ESP. No DSC. No TCS. No ABS. Just my right foot between me and oblivion. Oh - And a seatbelt.
Offline Rhyso
« Reply #3 on: 24 October 2006, 15:03 »
I think USB is fine; HEX is more for garage owners etc.
Best thing to do is to drop them and email and they should be able to advise you  :smiley:
It uses a cable from the USB on your PC to the serial port in the car
