Author Topic: Help! My Golf has shat itself  (Read 881 times)
Offline Coog
« on: 20 October 2006, 13:58 »
Can anyone tell me what the distributor cap is connected to? Been having a few minor issues and went to change the rotor arm only to find that the metal spinning jobby has ballsed iteslf on the wiring/other plastic stuff in there. I havent a clue what it is... was thinking dizzy cap but I cannot find a dizzy cap in the parts manuals...
If you know what it is can you let me know where I can get one/part no.
Many many thanks!
MK2 Golf GTi 16v
Offline Gambit
Re: Help! My Golf has shat itself
« Reply #1 on: 20 October 2006, 14:02 »
that'll be the actual distributor. what exactly is wrong with it?
Offline Gambit
« Reply #2 on: 20 October 2006, 14:04 »
a pic to help you explain!!
Offline Coog
« Reply #3 on: 20 October 2006, 14:09 »
The metal disk with the slots in it has caught wiring underneath it  :sick:. The metal disk appears to have bent (probably due to me hoking the rotar arm out) and then caught up on the internals when it was spinning when i started the car. Feel like such a b'bag right now...
Full distributor required then?
Heres the culprit:
MK2 Golf GTi 16v
Offline Gambit
« Reply #4 on: 20 October 2006, 14:15 »
ah so you have severed the hall sender wiring!
due to the amount of damage your better off getting a new one. hall senders can be replaced but the damage on the metal disk is too much
get a Bosch one outta Euro carparts and ask for your man Davey - tell him your part of NI clubgti for discount!
for future ref.... to get the rotor arm off you just crack the plastic with a pair of pliars!!
Offline Coog
« Reply #5 on: 20 October 2006, 14:16 »
Cheers mate, been a great help. will call him now. GSF have none in stock atm
MK2 Golf GTi 16v
Offline Coog
« Reply #6 on: 20 October 2006, 18:22 »
Got the new distributor fitted, came with a new arm & cap so no dismantling required (thank fook), though I had to hand my old one in for the bosch exchange service. After a bit of fiddling and changing the mounting position of the distributor I got it running, also changed the sparks, flushed the engine & got some fully synthetic oil in, changed the oil & fuel filters, reinstalled the fuel cut off valve & for good measure ordered a K&N panel  :grin:
now running 10 times better than before...
Thanks for your help lad... i owe you a pint  :wink:
MK2 Golf GTi 16v
