Author Topic: porsche rims?  (Read 738 times)
Offline toolow
porsche rims?
« on: 19 October 2006, 21:58 »
Hiya
Im casing some porsche rims on e-bay at the mo, 7x16 front and 8x16 rear, other than adaptors will i need any mods to get them to fit? (rolled arches etc) Also what size tyres do you think?
Car is a mk2 Jetta GTI Valver standard height at the mo but about to be dropped 60mm.
Cheers for any help
Offline Gambit
Re: porsche rims?
« Reply #1 on: 20 October 2006, 09:57 »
you need to make sure you are getting the correct offset porsche wheels. your looking about et52 if i remember correctly.
this offset with adpaters allows you to run them without any arch rolling/cutting
Offline toolow
Re: porsche rims?
« Reply #2 on: 20 October 2006, 15:11 »
yep they are 52et so with adaptors should bring them out to 27et my main concern is are 8" too wide for the back? and what tyres can i get away with on there?
Offline Uku
Re: porsche rims?
« Reply #3 on: 20 October 2006, 22:19 »
regardless of tyres i think from what ive read that with 60mm lowering and 8" width especially with that offset ur gonna have to roll the arches. im going to do mine myself , gonna cut away the arch then seam weld them , then G60 arches with the inner lip cut away should do the job.
Offline golfpro
  • If in doubt, pay someone else to do it!
Re: porsche rims?
« Reply #4 on: 21 October 2006, 08:29 »
Yep, get those arches rolled. Will look cool though!
thats the best mk3 ive seen..ever! its just clean and subtle.. :cool:
