Author Topic: Head up  (Read 2506 times)
Offline ReDBull
Head up
« on: 16 October 2006, 16:30 »
Anyone hear of an after market head up display? Would be a big help with DSG.
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Offline The Doc
  • E63s Estate - Vito Sport
Re: Head up
« Reply #1 on: 16 October 2006, 17:20 »
Agreed I'll find out BUT it would be difficult with the car having a can-bus system!
I think VW should have a "page" in the fuel computer that is just the gear that you are in. i.e. a big 1 or R or S etc   :drool:
Here is a crappy one: http://cgi.ebay.co.uk/Head-up-Display-gauge-project-speed-RPM-on-windscreen_W0QQitemZ160036581295QQihZ006QQcategoryZ72215QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
« Last Edit: 16 October 2006, 17:37 by The Doc »
Offline ReDBull
Re: Head up
« Reply #2 on: 17 October 2006, 10:04 »
Yes that does look a bit ropey. Evan a shift light similar to the Enzo would be a help. It really pees me of when I hold on to long to shift up and both me and the car go up a gear (two gears!!!). Wish VW had just fitted a rev limiter, it's the one down side to DSG for me.
Offline overthehill
Re: Head up
« Reply #3 on: 21 October 2006, 23:37 »
In theory shouldn't it be easier?  The gear, revs, speed etc will all be transmitted on the CAN-Bus, so an adaptor (into a reader) onto the bus should be able to tap into that info?
Offline The Doc
Re: Head up
« Reply #4 on: 22 October 2006, 17:00 »
Correct, the can-bus adapter is circa £120+VAT
Offline ReDBull
Re: Head up
« Reply #5 on: 23 October 2006, 09:16 »
OK chaps i was with you till you said CAN-Bus?????
