Author Topic: brake pad sizes  (Read 902 times)
Offline rud
brake pad sizes
« on: 16 October 2006, 15:59 »
does anyone know what the sizes of the brake pads are on an 89 reg 16 valve, just saves me having to take the wheel off and measure mine,
andy
Offline Gambit
Re: brake pad sizes
« Reply #1 on: 16 October 2006, 17:50 »
they should be 256mm brake disc's. so you need pads to match the 256mm setup
Offline J.stafford16v
Re: brake pad sizes
« Reply #2 on: 16 October 2006, 18:01 »
Isn't 89 the change over year when they went from 239mm to 256mm, if so I would check. :wink:
Offline Gambit
Re: brake pad sizes
« Reply #3 on: 17 October 2006, 09:02 »
the last of the 16v small bumpers (F-reg's) also had 256mm brakes
so yours should have them. but checking probably isnt a bad idea
« Last Edit: 17 October 2006, 09:04 by Gambit »
Re: brake pad sizes
« Reply #4 on: 17 October 2006, 16:09 »
You'll have to check, remember some early spec MK2s got registered as late as a G plate!  AFAIK only big bumper 16vs got 256mm brakes, but I may be wrong.
Offline rud
Re: brake pad sizes
« Reply #5 on: 17 October 2006, 18:06 »
cheers for the help guys appreciated, if my discs are 239mm is it easy to do a conversion to 256mm discs
Offline Gambit
Re: brake pad sizes
« Reply #6 on: 18 October 2006, 09:43 »
late small bumpers got 256mm's. i have one ;)
Offline rud
Re: brake pad sizes
« Reply #7 on: 24 October 2006, 19:24 »
yeah there 256mm, cheers for the help guys, appreciated  :smiley:
